Normal users should use the current Final version of XnView, which is version 1.70.4. Please see post XnView 1.70.4 for details.
A RC4 is available here:
http://www.xnview.com/beta/XnView-RC4.zip
Thanks to contact me if you find bugs.
Now you have a dialog box for copy/move to to show original/existing picture. Please test it!
Regards. Pierre.
XnView 1.74 Release Candidate 4 (Windows)
Scan headers option.
Always:
Bug. Headers not scanned on HD.
Bug? Headers not scanned on virtual disk.
Never:
Bug. Headers are scanned on HD.
Ok. Headers not scanned on virtual disk.
Exclude floppy|DVD:
Ok. Headers are scanned on HD.
Bug? Headers scanned on virtual disk.
Only on fixed disks:
Always:
Never:
Exclude floppy|DVD:
Ok, alawndart wrote:Scan headers option.
Always:
Never:
Exclude floppy|DVD:
No thumbnails. I always use 'view as details' mode.xnview wrote:Sorry i have not the problem??? Which view mode do you use? Thumbnails?lawndart wrote:When 'browse with Xnview' extension is used with
windows explorer, no files appear unless refresh
is selected. Win2k SP4. Should this be done automatically?
Probably my mistake again. Deleting very old xnview.ini file, I can get
to work as expected with default settings.
Update== this happens because of the "dont start browser thumbnail"lawndart wrote:When 'browse with Xnview' extension is used with
automatically?
option being selected, which also causes files not to be listed under
any other mode. So it might be bug.
