Crash when Options --> View --> File List
Questions, suggestions, and answers for XnView on all Un*x platforms (Linux, HP-UX, AIX, ...)
Moderators: XnTriq, xnview
Eclipse
Post by Eclipse » Tue Oct 17, 2006 1:46 pm
As the subject of this thread suggest I'm having this crash every time I select that option.
I'm running SUSE Linux, XnView v.1.70
The following is the output from shell ( Error detected appears when I hit File List):
 $>xnview
** XnView v1.70 Copyright 1991-2005 Pierre-E Gougelet (Sep  6 2005/13:16:40) **
        Version for Linux x86/Motif (All rights reserved)
** This is freeware software (for non commercial use)
     Type xnview -help, for more information
Warning:
    Class: XmTextField
    Character '\57' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\150' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\157' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\155' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\145' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\160' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\141' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\147' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\156' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\111' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\115' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\101' not supported in font.  Discarded.
Warning:
    Class: XmTextField
    Character '\107' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
    Character '\116' not supported in font.  Discarded.
Warning:
    Class: XmTextField
Warning:
    Class: XmTextField
****** Error detected ******
BTW this software Rocks! I just discovered it and I think it's going to be my favourite for a long while... :D
WDef
Post by WDef » Sun Oct 29, 2006 1:19 pm
Unfortunately we're having this problem using the RedHat static xnview binary on Damnsmalllinux, too.
strace -fivp says there is a segfault.
With the -c option there appears to eb a problem reading/accessing something.
This internet cafe's pc is infected with malware preventing pasting into firefox, otherwise I'd paste the output.
WDef
Post by WDef » Sun Oct 29, 2006 1:23 pm
My apologies for the multiple posts! - it didn't appear to be posting at all - said "error - timed out - debug mode" - so I kept trying to post. When I revisited the site ....
WDef
Post by WDef » Mon Oct 30, 2006 9:32 am
Here's what gdb says:
<snip>
(no debugging symbols found)...
Program received signal SIGSEGV, Segmentation fault.
0x4002c160 in XtWidgetToApplicationContext () from /usr/X11R6/lib/libXt.so.6
(gdb)
Post by xnview » Wed Nov 01, 2006 2:36 pm
WDef wrote:Unfortunately we're having this problem using the RedHat static xnview binary on Damnsmalllinux, too.
Ok, i'll check on damnsmalllinux. And which version of Suse do you have?
WDef
Post by WDef » Thu Nov 02, 2006 11:47 am
Thanks Pierre! Great the way you get on the case so quickly.
I'm just wildly (probably foolishly!) guessing but is it possible that:
1. Function XtWidgetToApplicationContext () is been handed an incorrect argument for some reason? Or:
2. There's a problem with Motif and libXt. Googling I found examples of similar(?) problems in other applications where motif had been statically compiled in - led to some kind of clash between libXt versions I think.
Eclipse
Post by Eclipse » Wed Dec 13, 2006 11:44 am
The SUSE I used was a 9.1 pro
WDef
Post by WDef » Sun Jan 14, 2007 2:22 pm
Any news on this?
duke74
Post by duke74 » Wed Oct 10, 2007 1:30 pm
hi also have problem with xnview 1.70 static rh6 vers. on this issue
possible workaround to manually edit ~/.xnviewrc
for unavailable options and stay clear of view /file list
my test system Mandrake 10.0 community
however, after instaling Openmotif 2.2.2 binary from
http://www.motifzone.net/index.php
find out that XnView-openmotif2.2.i386.rpm
(that is version 1.68 ) is working on this issue
dont know about other issues
is it possible to add XnView-openmotif for v1.70?
(at least temporarily,awaiting impatiently for new 1.90 :) )
