Default toolbar icons demopage
mezich
Re: Default toolbar icons demopage
Post by mezich »
JohnFredC wrote:From my perspective, #4 and #5 are just a "muddle"... too many colors and shapes to communicate effectively. :?
PS. Aren't color depth and palette really the same thing?
Yes. But in #5 more semantic weight: arrows=conversion between two different shapes - circle & square=full & fixed colors. Sorry for my English. So that's because I think #5 will be better.
JohnFredC
Post by JohnFredC »
None of the first group work for me... they are too much "photographic" and their messages are ambiguous.
#1 reminds me too much of "Copy".
#2 is OK but needs a "neutral" canvas. When we change the canvas size we assign a single color.
Here are suggestions:
John
mezich
Post by mezich »
JohnFredC wrote:None of the first group work for me... they are too much "photographic" and their messages are ambiguous.
Thanks. But #1 looks like current Fullscreen
JohnFredC
Post by JohnFredC »
mezich wrote:Thanks. But #1 looks like current Fullscreen
Yes, I guess it does. :( But the full screen icon does not show the second (larger) image.
Here is a crude color depth suggestion. The diagonal across the square is a common metaphor.
John
mezich
Post by mezich »
Good for preview image "show indexed/full color". Not for convert. That's because I used arrows.
mezich
Post by mezich »
Yes. Not show. But arrows tell us that image size will be increased and no reduced.
May be adding bidirectional arrow in my version between two images will be good for you?
JohnFredC
Post by JohnFredC »
mezich wrote:May be adding bidirectional arrow in my version between two images will be good for you?
Sure, double arrows would better address the resize meme. They would be rather small in that icon, though. Maybe another icon layout would work better.
I repeat myself from previous posts:
Good icon design is the most difficult part of software.
John
So what's the result :-)
If will be good if i could add these icons in XnViewMP (for next week)
mezich
Post by mezich »
1, 3, 5 ImageResize
2, 4, 6 CanvasResize
my vote is 5, 6
I like 5 & 6 too
mezich
Post by mezich »
xnview wrote:So what's the result :-)
Demopage updated http://www.mezich.ru/xnview/demo/
As I know in XnViewMP 24x24 not used. Only 16x16.
Should I make 16x16 version?
JohnFredC
Post by JohnFredC »
I don't care for No. 2 but any of the rest are more than suitable.
To make things easier:
5 & 6
8)
John
mezich wrote:As I know in XnViewMP 24x24 not used. Only 16x16.
24x24 icons are used in toolbar, and 16X16 in menu, so it's not needed... Thanks!
Perhaps 'Send by FTP', 'Levels' & 'Shadow/highlight' too???
mezich
Post by mezich »
JohnFredC wrote: Here is a crude color depth suggestion. The diagonal across the square is a common metaphor.
Alternative way for "Change color depth" is represent most common usage. By my opinion this is decrease count of colors. What do you think?
