Toolbar skins for XnView Classic
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
naymad
Re: Toolbar skins
Post by naymad »
Pierre, I understand, you want to package it?
If, of course.
Greetings. naymad
Re: Toolbar skins
naymad wrote:Pierre, I understand, you want to package it?
If, of course.
Greetings. naymad
Ok, i'll add it, you are the author of icons?
naymad
Re: Toolbar skins
Post by naymad »
Have been made ​​by me with Paint.NET 5.3.10.
Sources: icons for Windows 8 in Internet.
Screenshot of Windows 7 Explorer. Detail
Captura de Pantalla del Explorador de Windows7. Detalle
naymad
Re: Toolbar skins
Post by naymad »
Hi Pierre, greetings.
In the folder skins / metro of XnView 2.00 should be replaced the following names:
Thank you.
naymad
Re: Toolbar skins
Post by naymad »
In the folder skins / metro of XnView 2.04 should be replaced the following names:
Thank you.
Re: Toolbar skins
naymad wrote: In the folder skins / metro of XnView 2.04 should be replaced the following names:
right, thanks
Mirada2000
Re: Toolbar skins
Post by Mirada2000 »
Link for Download skin metro for xnview MP ?
Dirk13
Re: Toolbar skins
Post by Dirk13 »
Hello, does anybody have a toolbar skin with *larger* icons?
Currently, the icons aren't scaled up - at least with Windows 7 - and can get quite small on high resolution screens.
http://newsgroup.xnview.com/viewtopic.php?f=35&t=29649
Thank you!
Moderator & Librarian
Re: Toolbar skins
Dirk13 wrote:Hello, does anybody have a toolbar skin with *larger* icons?
Workaround to increase the size of the icons on the main toolbar:
  1. Download mezich.png and open it with XnView.
  2. Resize it to 200% (Nearest Neighbour) and save it as %ProgramFiles%\XnView\skins\mezich_48\main32.bmp.
  3. Copy & paste the following text to NotePad and save it as %ProgramFiles%\XnView\skins\mezich_48\info.txt.
  4. Go to Tools » Options... » Toolbar » Skin and select Mezich 200%.
label = "Mezich 200%"
version = 3
auto = 0
width = 48
height = 48
main32 = 1
browser = 0
browser32 = 0
tabtree = 0
icninfo = 0
imbar = 0
jpgbar = 0
Related topic: Size of Overlay Icons
Dirk13
Re: Toolbar skins
Post by Dirk13 »
Hello XnTriq ... BTW: nice user-name :-)
I followed your instructions. 200%, same path and filenames.
In the Options, I'm offered the Mezich 200, but only the name - no icons visible.
If I activate it, it looks like the screenshot I attached.
Re: Toolbar skins
Dirk13 wrote:Hello XnTriq ... BTW: nice user-name :-)
Thank you, Dirk13 (-:
(I'm not uniq, though.)
Dirk13 wrote:In the Options, I'm offered the Mezich 200, but only the name - no icons visible.
Sorry about that. Could you please try changing version = 3 to version = 4?
Dirk13
Re: Toolbar skins
Post by Dirk13 »
Ah, better! And I also made a mistake with resizing.
Thank you, this helps for now.
But not a solution for the average user. ;-)
tekra
Re: Toolbar skins
Post by tekra »
Thank you thank you thank you...
Re: About HiDPI support
Installing a hi-res version of the Mezich skin for the main toolbar:
  1. Create a new directory in the skins subfolder of your XnView installation and name it mezich_48.
  2. Use XnView to convert the attached PNG file to BMP format and save it as XnView\skins\mezich_48\main32.bmp.
  3. Copy & paste the following text and save it as XnView\skins\mezich_48\info.txt.
    label = "Mezich 48×48 (www.mezich.ru)"
    version = 4
    auto = 0
    width = 48
    height = 48
    main32 = 1
    browser = 0
    browser32 = 0
    tabtree = 0
    icninfo = 0
    imbar = 0
    jpgbar = 0
  4. Go to Tools » Options... » Toolbar » Skin and select Mezich 48×48.
Dreamer
Re: Toolbar skins for XnView Classic
Post by Dreamer »
Hello, here are few skins from me, 3 different styles.
License is included in each skin folder.
Dream Flat Pro
Dream Flat Pro 32 by Dreamer
Dream Flat Pro 64 by Dreamer
Dream Flat Pro Greyscale 32 by Dreamer
Dream Flat Pro Greyscale 64 by Dreamer
Dreamer
