** English - English (=Master)
Translation of On-Screen texts of XnView MP and XnConvert
vertigo
Re: ** English - English
Post by vertigo »
I'm a little late to the party on this one, but here's my thoughts on a few of the discussed options:
helmut wrote:
XnTriq wrote:Yes, “Allow only one instance of XnView” seems to be the best option for an application that consists of a browser and a viewer ...
O.k., let's use this (unless someone contradicts).
+1 (and I see this is the current label in 0.84, so I'd say this option is good.
As to the ones I inquired about elsewhere, and that seem to be causing quite a bit of confusion:
'Multipe view for same file'
- what it does: allows multiple tabs to be opened with the same image
- suggested replacement label: 'Allow (opening) more than one instance of a file' OR 'Allow multiple tabs for/of same file'
'Only one view per file''
- what it does: opens multiple files added at once via multiple selection and Ctrl+O shortcut* or dragging and dropping
- suggested replacement label: 'Open multiple simultaneously added files in one tab' OR 'View files in one tab when opened/added at the same time / at once / simultaneously' **
**Not sure if it's a bug or intended behavior, but opening multiple files at once by selecting them in the browser and pressing enter always opens them in one tab, and using the Ctrl-O shortcut always opens them in multiple tabs, regardless of this setting, which made me think the setting wasn't working right for a while. If a bug, it should be fixed. If not, the setting should be clarified to indicate that it applies to dragging and dropping only (and the shortcut??, since I'm pretty sure others said it works that way for them).
Edited to fix shortcut and add additional info about shortcut not working as expected with option.
Thank you, vertigo, for your thoughts on the naming of the options.
We should make a final decision on the naming so that Pierre can implement this in 0.85.
Suggestion:
"Multiple view for same file" -->
"Allow opening multiple views/tabs for same file"
"Only one view per file" -->
"Startup and drag&drop: Open only one view/tab for multiple files"
Note:
Why "view" and not "tab"? Tabs are used to switch inbetween views; some people don't use tabs.
Reason: Added "tab"
vertigo
Post by vertigo »
I'm not even sure how you could have multiple views without multiple tabs, but how about instead of "tabs" or "views" saying "views/tabs?"
vertigo wrote:I'm not even sure how you could have multiple views without multiple tabs, but how about instead of "tabs" or "views" saying "views/tabs?"
Yes, "views/tabs" is better. I've just changed my previous post accordingly.
Kolor Crash reporter of XnView 0.85 beta 1:
"Thanks, we will do our best to solve it." -->
"Thank you, we will do our best to solve this problem."
XnView 0.85: Inconsistent naming:
Settings: Interface » Toolbar
"Browse mode"
"View mode"
Settings: Interface » Shortcuts
"Browser mode"
"Viewer mode"
Suggestion:
"Browser"
"Viewer"
helmut wrote:XnView 0.85: Inconsistent naming:
"Browse mode"
"View mode"
"Browser mode"
"Viewer mode"
Suggestion:
"Browser"
"Viewer"
+1
Those are the terms normally used...
cday wrote:
helmut wrote:... Suggestion:
"Browser"
"Viewer"
+1
Thank you for seconding, cday. In the not too far past we used the terms "Browser mode" and "View mode" in the forum. But during the years the wording here in the forum has changed to "Browser" and "Viewer" (or "View") which is easier to understand. "View" is also used in some areas (e.g. category "View"), perhaps this can be checked and changed step-by-step to "Viewer".
helmut wrote:Kolor Crash reporter of XnView 0.85 beta 1:
where do you have this string?
The message box with this string is displayed right after pressing "Upload" button.
helmut wrote:The message box with this string is displayed right after pressing "Upload" button.
ok, i can't change it, the message comes from kolor server
O.k.. Perhaps you can send Kolor the suggested English text.
0.84 Browser - context menu of a file:
Set comment -->
Edit comment
(analog to "Edit IPTC/IIM data")
Dialog "Create Contactsheet" (Browser: Tools » Create Contact sheet | Settings)
Tumbnails per page -->
Thumbnails per page
Below please find various suggestions/corrections for the English translation of XnView 0.89 b1.
Please note that I'm not a native speaker - suggestions/corrections for the suggestions/corrections are welcome.
"Create Splitted files, please wait..." -->
"Creating splitted files, please wait..."
"Please visit the wiki for more information." -->
"Please visit the XnView Wiki for more information."
"Curves" -->
Brilliance and RGB (Curves)
"Save script" -->
Save grid
"Categories tree is correclty imported in XnView category" -->
Category tree was successfully imported into XnView categories"
"View all icon file's as snapshot" -->
View all icon files as snapshot"
"Rebuild embedded thumbnail" -->
Rebuild embedded EXIF thumbnail
<location filename="InfoCategoryView.cpp" line="987">
"Edit..." -->
Properties...
"Reset XY (Not fit)" -->
"Reset XY (No fit)"
"Click to change between width of thumbnail and number of thumbnails per column" -->
"Click to switch thumbnail control: Width or number per column"
"Path to destination does not exist." -->
Destination path does not exist."
"Force: Cannot remove destination file." -->
"This operation can delete some entries from DB which have ratings, colors and/or keywords assigned. Do you want to check for these before?" -->
XnView crash reporter:
"To help us at improving the software and your user experience, you can upload the report file or send it at contact@xnview.com." -->
"To help us in improving the software and your user experience, you can upload the report file or send it to contact@xnview.com."
"Note: this email box is used only for this matter and we don't answer to question ask through this email. Our support is done through contact page available at ..." -->
"Note: This email box is used for technical crash reports, only, and we don't answer to questions sent to this email box. You can contact our support via the contact page available at ..."
"(Your email is important if I need to contact you)" -->
"(Your email is important if we need to contact you)"
