The picture does not update
Moderator & Librarian
Re: The picture does not update
Does this issue only occur in conjunction with Photoshop, Waiman?
What happens, if you repeat your tests using MS Paint to edit the image(s) without Photoshop running in the background?
Waiman wrote: Sun Dec 22, 2019 6:48 pm
xnview wrote: Sat Dec 21, 2019 1:57 pm do you have same problem with 0.94.2?
0.94.2 has same problem.
Strange, i can only reproduce on Windows 7, no Windows 10
Waiman
Post by Waiman »
XnTriq wrote: Mon Dec 23, 2019 12:30 am Does this issue only occur in conjunction with Photoshop, Waiman?
I tested install the new Win7 Pro, then install XnView MP, and install Total Commander, without any other software. still have same problem.
Waiman wrote: Mon Dec 23, 2019 1:18 pmI tested install the new Win7 Pro, then install XnView MP, and install Total Commander, without any other software. still have same problem.
Thanks for checking!
Waiman
Post by Waiman »
XnTriq wrote: Mon Dec 23, 2019 9:30 pm
0.94.3 still have same problem.
Waiman
Post by Waiman »
0.98.2 Still hasthe same problem. Over one year now and the bug was never fixed!
