Xnview MP Dark UI Enhancement
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
orbspider
Re: Xnview MP Dark UI Enhancement
Post by orbspider »
well I figured how to turn off the preview in the info pane so that solves it for me. :?
Moderator & Librarian
orbspider wrote:I found it searching the same problem as noted (and somehow solved) by arabtornado, how to change backgd color of PREVIEW panel
but not Preview bkgd, correct? So how do I do it, as my dark themes is looking good.
Tools » Settings... » Browser » Preview background color
orbspider wrote:Another thing, how to change the selected thumbnail having blue-white box around it and the selected thumbnail label dark blue? I'd like to make them just maybe lighter grey. If that's Qt style sheet then where do I find those in Linux Debian?
The following INI entry only works in XnView v1.9:
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Browser]Browser[/url]) wrote:
SelBorderColor
  • Changes the color of the selection frame around the selected thumbnail.
    Value: Raw color (integer) or formatted color string
    See also FolderColor# settings
There's a similar entry in the xnview.ini of XnViewMP v0.53 (Wndows), …
[Appearance]
selectedColor=10 36 106
… but (manually) changing the value doesn't seem to have any effect :?
orbspider wrote:Also, how do I change the white 1px line to left of each pane, as arabtornado doesn't have them?
MyThumbListView,
QTreeView {
border: 1px solid black;
orbspider
Post by orbspider »
Hi thanks for the help!
I have this in my css
QTreeView#UIGroup_TreeView QHeaderView::section:first{
    border-left: 1px solid black;
and lower down:
QTreeView{
    background-color: rgb(20, 20, 20);
    alternate-background-color:  rgb(40, 40, 40);
    border: 0px groove rgb(70, 70, 70);
but originally it was
QTreeView{
but both give white vertical lines at dividers, left side
orbspider wrote:[...] but both give white vertical lines at dividers, left side
Forget about MyThumbListView & QTreeView! This oughta do the trick:
Qt Reference Ducumentation (Qt Style Sheets Examples » [url=http://doc.qt.digia.com/stable/stylesheet-examples.html#customizing-qmainwindow]Customizing QMainWindow[/url]) wrote:The separator of a QMainWindow can be styled as follows:
QMainWindow::separator {
    background: yellow;
    width: 10px; /* when vertical */
    height: 10px; /* when horizontal */
QMainWindow::separator:hover {
    background: red;
orbspider
Post by orbspider »
hey that's it, well not the yellow but that's the one to adjust (grey and 2px for me)
It's good to have a librarian around!
just one more, when Tree tabs are vertical there's a white line from them all the way down!
orbspider wrote:It's good to have a librarian around!
Yep, we're the unsung heroes :P
orbspider ([url=http://newsgroup.xnview.com/viewtopic.php?p=89171#p89171]Qt Stylesheet Snippet Repository[/url]) wrote:just one more, when Tree tabs are vertical there's a white line from them all the way down!
This one remains a complete mystery to me :-|
JohnFredC ([url=http://newsgroup.xnview.com/viewtopic.php?p=89171#p89171]Qt Stylesheet Snippet Repository[/url]) wrote:Unfortunately, none of those affect the line arrowed in the following image:
orbspider
Post by orbspider »
perhaps its part of the Tabs widget that would get drawn under tabs but their giff image covers it.
oh well! cheers
orbspider wrote:perhaps its part of the Tabs widget that would get drawn under tabs but their giff image covers it.
So far, I've tried these properties/pseudo-states/subcontrols:
  • QTabWidget
    • QTabWidget::pane
      QTabWidget::tab-bar
    QTabBar
    • QTabBar::tab
      • QTabBar::tab:first
        QTabBar::tab:middle
        QTabBar::tab:last
      QTabBar::Shape
      • QTabBar::RoundedNorth=0
        QTabBar::RoundedSouth=1
      QTabBar[shape="0"]::tab
      QTabBar[shape="1"]::tab
      QTabBar[shape="2"]::tab
    MyTabWidget
    • MyTabWidget::pane
      MyTabWidget::tab-bar
    MyTabBar
    • MyTabBar::tab
@Pierre: Can you make the border “styleable” by setting QTabBar::drawBase() to false?
XnTriq wrote:@Pierre: Can you make the border “styleable” by setting QTabBar::drawBase() to false?
The QTabBar for tree view?
Yes. John's screenshot:
And this is the discussion on Stack Overflow I'm referring to:
Qt: hiding bottom line in QTabBar wrote:
Allur wrote:It seems like no possible to set stylesheet for bottom line QTabBar.
I need remove bottom line:
Please, help!
hus787 wrote:Haven't used Qt in 6-7 months now so I'm not sure if this will work nor can I test it. Give QTabBar::drawBase a try. Plus the Qt library are very well documents so you should find a solution to your problems if you just carefully sift through it.
Hope you are using the Qt SDK.
Allur wrote:Thank you! It works.
Not easy, it's not a QTabBar but a QDockWidget
Evil_D
Post by Evil_D »
How to make the color of the number 1 is the same as the color of number 2?
http://img402.imageshack.us/img402/5525/ghl.png
Evil_D wrote:How to make the color of the number 1 is the same as the color of number 2?
Changing the background color of the thumbnail panel (Tools » Settings... » Browser » Thumbnail » Appearance » Thumbnail cell » Appearance » Background) doesn't take immediate effect behind/under the folders :bugconfirmed:
As a workaround, you can force MP to redraw the folder thumbnails by changing the thumbnail size (View » Thumbnail size...).
In Batch processing of XnView MP with dark theme the labels and parameters are very hard to read:
(Tested with XnView MP 0.61 on Windows XP SP3)
