Addons/Plugins/...
herr_k.
Post by herr_k. »
@imageshack:
just downloaded the 1.01 version.
erm, the only change is the annoying popup-window,that is completely unnecessary? would be nice if you could drop a line what changed in the version*. maybe a textfile in the archive? thanx
@cleo: keep up the hope ;).
*in any plugin upgrade..
Dreamer
Post by Dreamer »
herr_k. wrote:@imageshack:
erm, the only change is the annoying popup-window,that is completely unnecessary? would be nice if you could drop a line what changed in the version. maybe a textfile in the archive? thanx
Oh yes, it's quite annoying, perhaps the checkbox and text "Do not show this message again" would help.
Dreamer
herr_k.
Post by herr_k. »
@imageshack: i just noticed that after saving the picture you want to upload eg after importing from clipboard when you upload it, it does nothing. only after opening the saved file you can upload it again.
btw would be also nice to choose from a format before uploading.
@dreamer:ah yes you're right, i didnt thought about the accidental click on "menu/filters/upload to imageshack" with trembling fingers when wipeing the 3 zeros out of your tax declaration.
an upload meter/status bar with an abort button would help the weak and shortsighted quiet better. .. if the button is big enough of course.
but hey, thanks for motivating users to write more feedback!
herr_k. wrote:@imageshack: i just noticed that after saving the picture you want to upload eg after importing from clipboard when you upload it, it does nothing. only after opening the saved file you can upload it again.
How that, you import something from clipboard, and you can't upload it?
You would like to use jpeg?
herr_k.
Post by herr_k. »
the error is solved in the 1.01 it seems..
jep, to choose between png,jpeg & gif.
with the option to choose the quality settings before uploading (like 94% jpg or 8 colors gif eg), but not affecting the normal quality (regular save) settings.
would be nice, cheers.
anonymous_user
Post by anonymous_user »
Is it normal for XnView to become unresponsive while uploading to ImageShack?
anonymous_user wrote:Is it normal for XnView to become unresponsive while uploading to ImageShack?
Yes you need to wait that the uploading is finished
Mike-RaWare
Post by Mike-RaWare »
The HD Photo plugin doesn't support 16 bit colors (in total, not per channel). Any chance to supporting that in the future?
Mike-RaWare wrote:The HD Photo plugin doesn't support 16 bit colors (in total, not per channel). Any chance to supporting that in the future?
Could you send me a sample?
Mike-RaWare
You got mail!
Sorry for the long wait, but I mailed the sample with the subject: "16-bit HD Photo".
Peter2
xemfpcl-plugin
Post by Peter2 »
On page http://newsgroup.xnview.com/viewtopic.php?t=11715 I found the hit for the xemfpcl-plugin.
Some remarks and questions:
- It is not included in the "all-plugins-package" from here:
http://download2.xnview.com/XnView-win-plugins.zip. Why?
- It is not listed on the plugin-page here:
http://pagesperso-orange.fr/pierre.g/xn ... ugins.html
- I tried it with a PCL and PCLXL file (both from RICOH) and kann not see anything. Why?
(I copied the USR-file to the Plugins-directory and enabled the PCL-association in Options.)
Peter
Re: xemfpcl-plugin
Peter2 wrote: - I tried it with a PCL and PCLXL file (both from RICOH) and kann not see anything. Why?
I don't know, im' not the author of this plugin
maadjordan
Post by maadjordan »
why not make a direct support to packjpg (*.pjg) files as i have to read directly like "razoraw" files..
XnView Arabic Support
Peter2
Re: xemfpcl-plugin
Post by Peter2 »
Peter2 wrote:...- I tried it with a PCL and PCLXL file (both from RICOH) and kann not see anything. Why...?
Addendum: I contacted the author; the result is:
The plugin is too old for current print-files, but the full version of the PCL-viewer can display it.
Peter
Re: xemfpcl-plugin
Peter2 wrote:... Addendum: I contacted the author; the result is:
Thank you, Peter, for your effort! :-)
