https://pixeldrain.com/u/PGTxdL9w
XnView Shell Extension
Re: XnView Shell Extension
I just upgraded from rev 4.1.6 to 4.1.10.... but with this latest version, HEIC files are no more supported !
I then uninstalled 4.1.10 and put again 4.1.6, and .heic files are supported again.
Actually, I did this upgrade, because I discovered a slight bug in 4.1.6, and was hoping it was fixed in the latest rev :
Even when "Use original file date/time for saved files" option is set, converting a file using one of the pre-defined format (using the "Convert into" menu) creates a new file having date/time of initial file (which is OK), but converting it with the other menu ("Convert....") in which we have to choose the destination format, creates a file with date/time set at current time.... which is NOT OK.
It would be great to have a new version, fixing this slight bug, and still able to manage .heic files.
Thank you in advance !
right it will be fixed in 4.1.11LaurentG wrote: Thu Jul 25, 2024 6:11 pm I just upgraded from rev 4.1.6 to 4.1.10.... but with this latest version, HEIC files are no more supported !
After more thorough testing, it was found that files with the Index Color model can be converted to all formats except JPG.GrayWolfson wrote: Sun Mar 24, 2024 12:22 amImages with the "Index" color mode are not converted
Please, download the file and try converting it to JPG.
Yes, I confirm, it's OK now. Thanks a lot !
I just installed XnShell Extension (last rev 4.1.11) on a Win11 Home laptop.... and menu DO NOT appear for .HEIC files
While it works on my other laptop, under W10 pro.
Is there something to do to have it working on W11 ?
For me it appears only in the classic context menu (right click a file, then select "show more options" or press shift + context menu key on the keyboard).
It should be possible to add it to the standard menu, Windows 11 has different API commands for each menu.
Is there an option somewhere which one should be used? (like it's done in WinRAR for example)
jfi: https://blogs.windows.com/windowsdevelo ... indows-11/
Hi all
Please add supporto to .webp images
To see and to convert
It's very annoying not to be able to manage them..
If a use windows explorer it works
But if i use EF Commander (older verion) it doen't work!
But the problem came only with .webp images
For example with .png it works...
TIA!
TIA!
I installed XnShell Extension (last rev 4.1.14) on a Win11...
but error message...below...(And file(XnShellEx64.exe) version info viewed "0.0.0.0"...)
IPersistFile::Save failed; code 0x8007007B.
(refer Attachment file...)
- Attachments
- xnviewext4114-info.jpg (111.13 KiB) Viewed 1002 times
- xnviewext4114.jpg (93.14 KiB) Viewed 1002 times
right, i fix itjdlee66 wrote: Mon Apr 28, 2025 8:33 am
Bug in the latest ver. 4.2.0.0: some mysterious "f" (placeholder?) in context menu instead of the image size
- Attachments
- XnViewShellExt_4.2.0.0.png (13.2 KiB) Viewed 375 times
rightaboy wrote: Tue Jun 24, 2025 11:45 pm Bug in the latest ver. 4.2.0.0: some mysterious "f" (placeholder?) in context menu instead of the image size
Hi Pierre,
two questions about XnView Shell Extension :
1) Where could we have the changelog history ? When we click on the corresponding button on web site, we arrive in this forum.... in which the changelog is not really available...
2) For several releases of XnViewMP now, when installing a new version, installer propose to install also the shell extension.
2.1) Is it the SAME shell extension than the "alone" one ?
2.2) In which version ?
2.3) Is it preferable to install both, or at the contrary to uninstall the separate installation of Shell extension and rely only on the version installed by XnViewMP installer ?
2.4) Any other comment on this topic ?
Thanks in advance for your answers !
