XnView Shell Extension
farglebargle
Re: XnView Shell Extension
Post by farglebargle »
xnview wrote: Fri Jul 09, 2021 8:59 am
welbot wrote: Thu Jul 08, 2021 7:47 am Is there a full list of which file formats this allows to show as thumbnails? I don't seem to be able to see any definitive list anywhere. Or is it capable of displaying all the formats that xnview supports? I don't really want the viewer as I have a setup I like already, so just want thumbnail displays :)
ShellExt can support all file formats as XnView (if you have the plugins)
Not entirely. While it's capable of converting to lots of formats, it only shows up as a right-click extension on a few of the more common ones, which prevents it from converting from many others. I just tried to convert a TGA (targa) file, and got nothing. Any way to add missing formats to the menu? I just upgraded to the latest version (4.1.5) hoping it would fix this, but it didn't, so any suggestions would be appreciated.
4.1.6 version released
SoCu
Post by SoCu »
I can't find a link for the 4.1.6 released version, can you tell me where to get it?
thank you
SoCu wrote: Wed Dec 07, 2022 8:22 pm I can't find a link for the 4.1.6 released version, can you tell me where to get it?
thank you
http://download.xnview.com/XnShellEx64.exe
On the home page XnShell version is still shown as 1.15... :wink:
aboy
Post by aboy »
xnview wrote: Mon Dec 05, 2022 10:06 am 4.1.6 version released
On x32 Win XP no problems on the first sight, preview and all works, but if click "Options..." - there is just appear completely invisible window, blocking Explorer and everything! Thanks God it can be closed by ESC.
No such bug in the previous 4.1.5
wgc214
Post by wgc214 »
Exact same problem here (Windows 10 22H2, 32bit XYplorer file manager). Version 4.1.6 64bit version seems to work on 64bit Directory Opus, but 32bit version appears to lock up on "Options..."
wgc214 wrote: Sat Jan 28, 2023 3:23 am Exact same problem here (Windows 10 22H2, 32bit XYplorer file manager). Version 4.1.6 64bit version seems to work on 64bit Directory Opus, but 32bit version appears to lock up on "Options..."
ok i'll check
wgc214
Post by wgc214 »
Thank you!
2Hb
Post by 2Hb »
I see XnView Shell Extension can show thumbnail of a JPEG file within zipped archive without compression.
But, it cannot show thumbnail of a PNG file within such archive, even if ShellExt supports all file formats as XnView.
Could you tell me why? I am using latest 4.1.6.
Here is my setting.
user848
Post by user848 »
Doesn't work on Windows 11. Even when pressing shift + right click
SoCu
Post by SoCu »
Convert CR2 to JPG does not respect the dimensions.
Hi, I try to convert a .CR2 file to JPG, it converts to JPG, but it does not respect the dimensions of the original photo.
The dimensions of the .CR2 file are: 5496x3670, and the JPG file has lower dimensions: 2748x1835.
Why it does not respect the same dimensions when it makes the conversion, is it necessary to configure something?
I attach an image if you want to check it.
I leave a link, because it does not allow me to attach the file with CR2 extension
https://drive.google.com/file/d/1kjuwC5 ... sp=sharing
Thank you.
PapaiMark
Post by PapaiMark »
I couldn't find which extensions shellex opens.
And it does not opens all the "supported extensions"
Which extensions shellex opens?
For others, I intend to create shell extentions via
... WriteRegStr HKCR "SystemFileAssociations\.mp4\Shell\XnView\Command" "" '"$ExeDir\XnView.exe" "%1"' ...etc etc.
And I noticed that SendTo does NOT work with most extensions, Including the basic TXT.
However, once XnView was manually opened, they are opened normally, so as mp4 and mkv files.
There is a complicated problem and distanced behavior between browsing inside XnView and opening "with" XnView (%1).
Masters, how you deal with it?
Титан
Post by Титан »
Suggestion: invert
Add "invert" command to XnShell context menu folder
Koogle
Post by Koogle »
can this convert to webp? ie all the settings I'd use in xnconvert?
seems the shell extension got left behind a bit?
