XnView Shell Extension
Re: XnView Shell Extension
V 4.1.5
- dark theme support
hinabita
Post by hinabita »
Is it possible to make the thumbnail of XnShell appear at the top of the new context menu in Windows 11?
I know that currently I have to select "Other", but I like the context menu in 11 and would like to see the XnShell thumbnail image added to it.
SoCu
Post by SoCu »
In Windows 11, when we select a menu option, when it shows the submenu, the image and the first menu disappears.
SoCu wrote: Sat Nov 27, 2021 5:31 pm In Windows 11, when we select a menu option, when it shows the submenu, the image and the first menu disappears.
with new version of ShellEx?
SoCu
Post by SoCu »
I had version 4.1 installed, when I saw that it was happening, I updated to version 4.1.5, and it is still happening.
And XnView MP 0.99.1 can't open *.webp files
SoCu wrote: Mon Nov 29, 2021 7:32 am I had version 4.1 installed, when I saw that it was happening, I updated to version 4.1.5, and it is still happening.
It works here, you have not changed the theme?
?? XnView MP supports webp
SoCu
Post by SoCu »
I haven't changed anything, I don't know how to change the Theme.
When I click on a *.webp file, it is not shown in full screen, it goes directly to open the XnView MP and show the file explorer, where an icon of the *.webp image is shown to show the image again in full screen, you have to click again on the icon to open it.
It does not open directly when you click on the webp file.
SoCu wrote: Mon Nov 29, 2021 2:30 pm I haven't changed anything, I don't know how to change the Theme.
I don't understand, i have that on a clean windows 11
you should have a problem in the webp registry entry...
SoCu
Post by SoCu »
Thanks, I will try to uninstall, and reinstall, without configuring anything, to see what happens, because the little configuration that I have put, is the same as I had in Windows 10.
By the way, in that step I also shows me the image, when the image disappears, is when a submenu Convert into > opens.
SoCu
Post by SoCu »
i can't reproduce
SoCu
Post by SoCu »
Hi, I encountered a small problem with the conversion of a *.CR2 image I use XnShell to convert to > JPG, the dimensions of the CR2 image is 5472x3648, but the image created has incorrect dimensions 2748x1835.
By the way, the CR2 and PSD image is not displayed in the XnShell window.
SoCu
Post by SoCu »
Hi, I am still testing, because it is annoying that the menu options disappear.
I have noticed that, by disabling the thumbnail, so that the image is not displayed:
Then when the second submenu is displayed, the first menu is still displayed.
On the other hand, if the option to show thumbnail is re-enabled:
when the second submenu is displayed, the first menu disappears.
Peter2
Post by Peter2 »
SoCu wrote: Sun Jan 09, 2022 1:05 pm Hi, I am still testing, because it is annoying that the menu options disappear....
All other menus from other software are OK?
Have you check your settings of your graphic-device?
SoCu
Post by SoCu »
The options of the graphic card I have never touched them, with no other program this happens to me.
