(Unofficial) XnView file association manager
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
Moderator & Librarian
Hello ckv,
how are things up North? Good to know that you are still around.
Just the day before the final release I had stopped by your homepage to see what's cooking. That's when I found out about the B5. :o
You should make new posts for betas instead of (or in addition to) editing your initial post, so everyone who's watching this topic gets notified in time.
XnTriq wrote:I already did some test runs and checked the changes made with Resplendence Registrar: works flawlessly so far.
For testing the betas of v1.1 and v1.2 I used Regshot.
ckv wrote:Updated the old iconset. (All labels are redone)
Nice job on the anti-aliasing!
  • Image
It reminds me of those enhanced bitmap fonts by ThePixelPlant or farba@deviantART, and the smoothing effect you can apply with defontPIXEL.
I see you've also updated the screenshot(s): Old vs. new. Moi likes the retro-style ASCII art header!
ckv wrote:
XnTriq wrote:[snip] Next, you should make an HTML version. For small applications I usually prefer plain text over bloated online help files. But I've seen your documentation for the ckv Self-Extractor Kit, and it looks very professional.
Hmm maybe. The thing is that xfam was meant be really simple program what anyone could use without any instruction, But at the time I made it I notice that this and this needs an explanation. :|
I'm glad you changed your mind and made a readme.html. That's the kind of online help I had in mind.
(We don' need no steenkin' WYSIWYG editor, right?)
Suggestions:
  1. I can has XnFAM automatically read XnView's path from HKLM\SOFTWARE\Classes\Applications\ and populate the related field (Path to XnView executable) accordingly?
  2. We still see that infamous -slide bug reappear from time to time.
    Do you think you could add an extra option to XnFAM that checks the HKLM\Applications\xnview.exe\shell\open\command key and fixes it if needed?
Oh, and happy Juhannus Day to you & yours! :)
ckv
Post by ckv »
XnTriq wrote:Hello ckv,
Just great. Thanks. :)
XnTriq wrote:For testing the betas of v1.1 and v1.2 I used Regshot.
I've been using Regshot too, but I have used older version from sourceforge. I didn't know about this version. :)
XnTriq wrote:Nice job on the anti-aliasing!
  • Image
Thanks. Believe it or not, but I made the 48x48 and 32x32 label texts with MS notepad and with MS paint. :D
And the ASCII style header was easter egg in v1.1 and it was real ASCII not a bitmap like in v1.2.
XnTriq wrote:
ckv & XnTriq wrote:[readme stuff snip]
Right. Though the readme is still unfinished... I just hate writing those darn things.
XnTriq wrote:Suggestions:
You already know, but xfam v1.2 rev is available with those changes.
ckit
Post by ckit »
Excellent work, ckv!
Huge thanks too :)
ckit
Post by ckit »
This utility doesn't work under Windows Vista 64 SP1 but then again neither do the associations in XnView 1.95.
ckv
Post by ckv »
Thanks ckit. Will it work if you run it as administartor?
If it still doesn't work, it might that so called application capabilities registry key is required before it works on vista.
ckit
Post by ckit »
Yes running as Administrator works but what I don't get is that I'm already logged into Windows as an Admin why the extra step of clicking "Run As Administrator"?
Microsoft trying to make things harder?
ckv
Post by ckv »
It's because xfam requests user execution level.
I made updated version that will requests admin execution level.
Edit: Actually xfam requested asInvoker execution level (which means that it should inherit execution level from the process that started it), but it still doesn't get administrator rights. So I guess explorer always runs with lower execution level. :D Vista is fun!
ckit
Post by ckit »
Thanks again, ckv!
ckv
Post by ckv »
Unofficial XnView file association manager v1.2.1
Changelog:
  • XnView exe path is now read from registry. Thanks to XnTriq.
  • xfam now fixes the XnView Applications registry key if necessary. (Related to infamous -slide bug.) Thanks to XnTriq.
  • Fixed Vista execution level problem. (Vista will request admin privileges again.) Thanks to ckit.
  • Changed default list behavior when creating associations.
  • Other minor changes and improvements.
orbtwin
Re: (Unofficial) XnView file association manager
Post by orbtwin »
I like very much this tricky software ... and i would like to know how to create "new icl files" for the most common types of image files.
My goal is to associate the most common image files with a "tango" icon
Thanks
ckv
Post by ckv »
orbtwin wrote:Hello,
Thanks
Icon editors usually come with a tool to create amd edit icl files. XnTriq has listed some good free icon editors here.
I have used IcoFX and Greenfish Icon Editor Pro, both can create and edit icl files.
NOTE: To create an icl file that is compatible with XFAM you need to put the icons in the icl file the same order as they are in XnView.exe. You can use the icl files that come with XFAM as sample.
mimorqleko
Post by mimorqleko »
Does this app solve the Windows 8 file association problem in XnView??
(if you have no idea what I'm talking about, please have a look at this: http://newsgroup.xnview.com/viewtopic.php?f=35&t=27413)
mimorqleko wrote:Does this app solves the windows 8 file association problem in xnview??
next release of xnview will fix that
mimorqleko
That's great news!! :D
