Overlay icons cosmetic update
Re: Overlay icons cosmetic update
user0 wrote: Thu Nov 16, 2023 4:13 pm btw, any plans for svg version?
how to create them?
xnview wrote: Fri Nov 17, 2023 6:46 am
how to create them?
you mean vector?
here is quick vector example for testing (.ai and .svg)
info@2x.zip
(53.98 KiB) Downloaded 190 times
once icons size is changed to square, further testing will be easier, eg
- add border to all icons
- adjust lines, sizes, etc
Moderator & Librarian
user0 wrote: Sat Nov 18, 2023 9:26 amhere is quick vector example for testing (.ai and .svg)
Great job, user0 :D
XnTriq wrote: Mon Nov 22, 2021 1:00 am
XnTriq wrote: Fri Dec 16, 2022 5:15 amOSB Sudio is an open source project which is also based on Qt. The themes consist of QSS and SVG files.
lphilpot
Post by lphilpot »
I was going to post a new thread, but this is closely related so I'll add my comment here instead.
It would be nice to make the ratings icons more visible, both on the thumbnails and the full screen view. In full screen view, the histogram overlaps the rating:
Hint - It's behind the blue histogram. :D
Maybe put a contrasting background behind the star?
Thanks.
Len Philpot
updated
overlay_icons_info.zip
(30.69 KiB) Downloaded 197 times
A
- single letter EXIF, IPTC, XMP
B
- multiletter EXIF, IPTC, XMP
- link icon rotated to mimic S letter (sidecar)
Example
cicciobello
Post by cicciobello »
Variant "A" is OK. I think it's more readable than "B".
user0 wrote: Sat Dec 02, 2023 3:04 pm - single letter EXIF, IPTC, XMP
single letter is better than?
cicciobello
Single letters are more readable when the size is small.
The complete "IPTC, XMP, etc" are better when the icons are large, otherwise they are difficult to read.
cicciobello wrote: Tue Dec 05, 2023 1:26 pmSingle letters are more readable when the size is small.
Yes, my old eyes agree :-P
Post by michel038 »
I suggest these two versions of the info.png file :
1)info_color_initial
(you can right click and "Save image as" ... info.png)
Xmp are green
But this one requires young eyes
Result (200% enlarged here)
