XnConvert is crashed if use SMT and recompress RAW Files
Xn User
Re: XnConvert is crashed if use SMT and recompress RAW Files
Post by Xn User »
What you can say now ?
You what learnin about this problem ?
Xn User wrote: Mon May 06, 2019 2:52 pm I can this )
This XnConverter with INI file ) easy extract and use ) https://yadi.sk/d/3faCbU1HUENjaw you can compare binary code with your product if you want )
I can reproduce only with the 32bits version, it seems that it's a memory problem. When you extract the CR2, it needs more than 150Mb by picture
Xn User
Post by Xn User »
Yes ) I sayd about 32 bit version only )
Because me need LuarWave JPEG200 format , whom not in 64 bit version.
I see two variant as fix this problem :
1) create so , what if detect CR2 file - always convert only single-thread mode and any other formats convert use multi-thread.
2) will very good if recompile all LuraWave based LWF , LDF , LWF JP2 to 64 bit
If can , please add in 64 bit version this plugins pack. So will be best!
Xn User
Post by Xn User »
Hi )
I understand what LuraWave JPEG2000 and LuraWave plugins in x64 version not included , but please , yet include this plugins in your x64 versions XnConverter ) I understand what you need buy license , but future this have to do. Future in x64 versions converter.
This need do only once.
Thank you.
