The picture does not update
Re: The picture does not update
Waiman wrote: Tue Nov 13, 2018 4:35 pm file reopen is same, not working.
If you use File>Reopen, the image is not updated?? And if you restart XnViewMP, no more problem?
Waiman
Post by Waiman »
Over ne year now, XnViewMP 0.94.1 still have same problem:
1) open 1.jpg.
2) click Enter.
3) Close/Quit XnView Ctrl+Q.
4) Replace 1.jpg.
5) open 1.jpg again.
6) click Enter.
7) Refresh F5. the photo can not update.
i can't reproduce, the thumbnail is correctly re-generated.
Waiman
Post by Waiman »
I test in my win7, and I test again install XnViewMP 0.94.1 to Vmware Windows7 pro, is same problem!
Waiman
Post by Waiman »
Please check this Screen Video Capture 1.avi
1.part01.rar
(2 MiB) Downloaded 85 times
1.part02.rar
(2 MiB) Downloaded 87 times
1.part03.rar
(676.92 KiB) Downloaded 85 times
Rick
Post by Rick »
I built a toolbar to hold all the things that I don't want to continually have hunt in the menus
Rebuild thumbnails is one of them :mrgreen:
Rick
Waiman
Post by Waiman »
xnview wrote: Mon Dec 16, 2019 2:23 pm i can't reproduce, the thumbnail is correctly re-generated.
One picture is the Tortoise LS Diet food and the other is gold.
Sometimes, I have to do it a couple times before the problem starts showing up. If it cannot reproduce with those previous steps, I found that if I continued with the following steps, then it will be able to be reproduced as well.
8 ) Close/Quit XnView Ctrl+Q.
9) Replace 1.jpg with Tortoise LS Diet photo.
10) open 1.jpg again.
11) click Enter.
Waiman
Post by Waiman »
I found no problem is set to Fullscreen - Browser.
but have that problem if set to Normal or Fullscreen - Viewer.
Waiman
Post by Waiman »
can you re-generated?
Waiman wrote: Wed Dec 18, 2019 5:46 am
no :(
Waiman
Post by Waiman »
xnview wrote: Wed Dec 18, 2019 1:55 pm
no :(
This is very weird! I am not sure why you cannot regenerate the issue.
I have tested again after reinstalling the new windows 7 in Vmware, then install XnViewMP 0.94.1 tested it again like in my Mon Dec 16, 2019 8:17 am post. I tried steps 1-7 and it did not appear. But if the problem does not occur, I repeated those steps again and it shows. Same as the videos 1.avi on Mon Dec 16, 2019 10:49 am post.
Waiman
Post by Waiman »
Please set to Normal and test again:
do you have same problem with 0.94.2?
Waiman
Post by Waiman »
xnview wrote: Sat Dec 21, 2019 1:57 pm do you have same problem with 0.94.2?
0.94.2 has same problem.
