XnViewMP very slow since last update
Re: XnViewMP very slow since last update
daVe55 wrote: Thu May 17, 2018 2:14 pm XnView MP v.90 is very slow to open any image compared to XnView Classic v2.44. When will the next version of XnView MP be released and will this slow response time be corrected? I am running Windows 10 x64 v1803 latest insider build.
slow how?
m.Th.
Post by m.Th. »
It would be best to make a screencast with your steps. If you cannot do this, then just write here the steps with details.
For example:
1. I go with XnView on c:\temp (it is important: HDD, SSD or LAN?)
2. I double click on IMG_001.CR2 (it is important: RAW, small jpeg or a big tiff?)
Expected:
Opened in Viewer <1 sec.
Actual:
Opened in Viewer in loong time. More than 5 secs.
m. Th.
daVe55
Post by daVe55 »
Steps?
Double-click on any graphic image associated with XnView MP. About 5 seconds later the image opens in XnView MP.
daVe55 wrote: Thu May 24, 2018 9:36 am Steps?
What do you have for settings>Mode when starting with a file? which OS? no tabs restored?
secarica
Post by secarica »
I experience the same thing (i.e. very slow start on first start with XnViewMP 64bit) since few years now. On each new release I expected this to improve, but nothing changed.
I experienced this with Vista, with 7 and now 8.1, all 64bit.
I am not using any antivirus on neither systems.
There is no difference after fresh clean Windows install or after few months since the last system and application install.
I only use it as click-per-picture viewer, never in browser mode.
The first thing after a clean install is to customize some settings, but -- in order to avoid some hassle -- sometimes I simply copy the .ini file from the to-be-erased system to the fresh reinstalled system, so the problem might be related to some particular settings I am used to, that I set to it right from the beginning.
secarica wrote: Fri Jun 22, 2018 8:24 pm I experience the same thing (i.e. very slow start on first start with XnViewMP 64bit) since few years now. On each new release I expected this to improve, but nothing changed.
If you use default settings, do you have same problem? The slow start is when you double click on image file in windows explorer?
