no thumbnails for video :(
hh11
Re: no thumbnails for video :(
Post by hh11 »
It works ! :D
Thank you very much !
Erixx haxx
Post by Erixx haxx »
I'm still having problems with this. I added
VideoFormat=3
To Browser Section of .ini file to look like this:
[Browser]
VHidePanel=0
VListLayout=0
VideoFrame=1
VideoFormat=3
VideoPlayBar=1
ViewColumn=255
Viewas=5
Even removed the thumbnail cache. All i can get is 1 .avi thumbnail to show up. XnviewMP works fine. I'm on win7x64 by the way
stussy
Post by stussy »
I got the same problem here :/
hh11
Post by hh11 »
just an idea
Did You wait long enough?
because after adding videoformat = 3, my first reaction was : It's a pity ! nothing has changed !
but slowly (very slowly) Thumbnails appeared progressively
It took a long time to build all of them I don't know why (more than for jpeg)
(Moreover, I use Xnview and my feeling is that XnVIEWMP is maybe slower to build thumbnails
but just a feeling)
FlyAway
Post by FlyAway »
I waited for the new version hoping that the problem was solved but nothing has changed. I also added the string but without success. :(
At this point, someone can recommend a portable program that let me see the thumbnail of the video? Thanks
FlyAway wrote:I waited for the new version hoping that the problem was solved but nothing has changed. I also added the string but without success. :(
do you have codec pack like "Klite codec"?
FlyAway
Post by FlyAway »
yes but no luck :(
Is strange becouse I have also XnViewMP and with it I haven't problem, the thumbnails function work perfectly, the problem is that I don't like XnViewMP :)
FlyAway wrote: Is strange becouse I have also XnViewMP and with it I haven't problem, the thumbnails function work perfectly, the problem is that I don't like XnViewMP :)
Strange, do you have quicktime codec?
And why you don't like XnViewMP? :)
FlyAway
Post by FlyAway »
I do not like it because:
- In xnview.ini, there are the voice "RecentFiles" and "History" that showing the files seen and I have not found a way to disable them
- The program cache continues to store folders visit
- Thumbnails seem less quality Xnview
- In "Auto image size" I have enabled "fit image to windows". When I change "browser" to "viewer" with the double click on the image, for 1 sec I see the original size image showing, It is very annoying
- displays thumbnails for all video formats but not for "flv" video
- icons are ugly (but this is also a problem of Xnview), forgive me :)
- Don't know how change the font size in "filelist toolbar"
quicktime codec....no, I installed it and I'd rather not install it because I do not like it at all :)
Thanks for your help and for your fantastic products
FlyAway wrote:I do not like it because:
So you would like that XnViewMP has an option to disabled history and cache?
It's the same quality...
XnView Classic shows thumbnails for .ftv and not XnViewMP?? Do you have AddOn/ffmpeg in XnView Classic and XnViewMP?
you means the folder tree view?
Ok, and you had video thumbnails with previous version??
FlyAway
Post by FlyAway »
Yes, for privacy is fundamental
I did not lose much time to set it up but it seems to me that Xnview has many more settings
XnView Classic don't work for the 80% of video formats (for me), XnViewMP don't works only with .flv
No, where it says the path to the folder you are looking
I have installed Zoom Player with your codecs and K-Lite Codec Pack
there is a way for solve the "- In "Auto image size" I have enabled "fit image to windows". When I change "browser" to "viewer" with the double click on the image, for 1 sec I see the original size image showing, It is very annoying"?
[/quote]
thanks!
FlyAway wrote: XnView Classic don't work for the 80% of video formats (for me), XnViewMP don't works only with .flv
Do you have AddOn/ffmpeg in XnView Classic and XnViewMP? XnView Classic is the 2.34?
[/quote]
it's possible by editing the theme
i'll check
FlyAway
Post by FlyAway »
I don't have ffmpeg addon in any of the two programs. Where I can find it? Yes, is the last version
ok
i'll check[/quote]
Thanks! :wink:
FlyAway
Post by FlyAway »
I have find, in the forum, you ffmpeg, I have dezippated it and put the 2 files it in the addon folder of XnviewMP, nothing is changed :(
FlyAway wrote:I have find, in the forum, you ffmpeg, I have dezippated it and put the 2 files it in the addon folder of XnviewMP, nothing is changed :(
AddOn\ffmpeg\ffmpeg.exe?
