B1 - B2 - B3 error sound moving inside the thumb view
Feedback and Comments on the new 1.96 Test version on Windows.
fxtech wrote:done , the test folder was empty before xnview start
and.. it sound. Tested even inside a vmware partition with a clean vista installation and it sound again
:-( I've tried on another vista, and no sound...
XnView has the rights to write in his folder?
fxtech
Post by fxtech »
xnview is not installed but just unzipped inside his folder , may be the fault is here..
fxtech wrote:xnview is not installed but just unzipped inside his folder , may be the fault is here..
Could you send me your email by PM, i'll send you a setup
fxtech
Post by fxtech »
i am a guest i cant send pm , but is not a problem, i iwll test my antispam filter :-)
fxtech wrote:i am a guest i cant send pm , but is not a problem, i iwll test my antispam filter :-)
Ok, i send you a version...
Locked
