Most important features
oops66
Post by oops66 »
Yes, for me too, the customization is one of the key way for the Xnview success !
thibaud
Post by thibaud »
One of the features I like best about XnView is its "visual" configurability. If everyone wanted XnView to look as much like LightRoom as possible, then I'd agree (because that would be all right with me).
But I doubt everyone does.
So I'll continue to hope that all of the existing customization (and more!!) will eventually be present in the MultiOS version, too.
Well I certainly wouldn't complain if the customization options would allow you to make the thumbnail only half looks like lightRoom ones :)
I Certainly have nothing against ui customization if :
1. the customization form is properly structured.
(right now many inter-dependent controls are not properly identified, sometimes hard to find and result are often unpredictable)
2. customization would extend an already solid design (in other words:You wouldn't need to use them to try to fix default ui design flaws.)
JohnFredC wrote: So I'll continue to hope that all of the existing customization (and more!!) will eventually be present in the MultiOS version, too.
For example, if you take a look at the thumbnails & labels, you have more settings than xnview win :-)
thibaud
Post by thibaud »
For example, if you take a look at the thumbnails & labels, you have more settings than xnview win Smile
Indeed, I noticed the new "use margin around thumbnail" feature. which is nice.
JohnFredC
Post by JohnFredC »
Maybe I don't have the latest version? The labels are more customizable, but that's about it so far.
There are fewer color customizations (none for the browser background colro), the border around the thumbnail is inaccurate and doesn't respect the thumbnail size, etc.
I know. A work in progress, but certainly not "more settings than xnview win" yet!
John
JohnFredC wrote:Maybe I don't have the latest version? The labels are more customizable, but that's about it so far.
You can configure color for labels by extension, by label entry, ...
Yes, there is some problems with some settings for thumbnails.
And color for widget such browser will use the general QT theme script
By the way, you want a setting to show thumbnail like lightroom?
thibaud
Post by thibaud »
a small image is worth a thousand...
so here is a very simple example of how the thumbnail could be styled.
allowing quite a few variation (from lightroom to acdsee) with not too many controls.
at the moment thumbnail styling in xnview is .. well, screwed if you want my humble opinion ;)
(picture borders are overlapping the cell, inside margin has no effect, label background are not filling the cell properly,etc..)
thibaud
Post by thibaud »
forgot to add:
selection feedback would also be much better identified if they were overlayed on the whole cell instead of the just a small red border around the thumbnail.
picture again:
thibaud wrote:(picture borders are overlapping the cell, inside margin has no effect, label background are not filling the cell properly,etc..)
Yes a bug, but in development :-)
Your example is very good!! :-)
On your sample, you have no shadow?
thibaud
Post by thibaud »
actually there is a dropshadow,
just enough to look good (pops the thumbnail up).
not to much so you don't notice it too much (instead of the thumbnail).
that's how a drop shadow should be used imho.
if you think about it, theses interface elements are not trivial or pure cosmetic they do serve a purpose
Could you send me a png of this sample (for the quality)?
JohnFredC
Post by JohnFredC »
Hi Pierre...
2Thibaud
I like your examples!
2Pierre It doesn't matter that XnView looks exactly like LightRoom (or any other software). Indeed, it probably shouldn't, so that the user doesn't confuse the two softwares when both are open on the diesktop. On the other hand, the aesthetic appearance of XnView IS important, as is the functionality.
The problem is that aesthetics and functionality differ per user.
This is where that modularity thing I keep bringing up applies. If you are going to the trouble to entirely rebuild XnView "from scratch", then you have enormous opportunity to be both innovative and complete in the implementation. Here is the one (and only!) opportunity to be innovative internally.
Suppose a thumbnail is considered as a user-defined collection of panels and controls:
The panels might be:
  • Header
    Top
    Left Side
    Right Side
    Thumb
    Bottom
    Footer
    Label(1..n)
Further, consider controls a user might place on a panel:
  • Graphical Notifiers (Rank, file type, stars, etc.)
    Graphical Notifier/Toggles (Check mark, for instance)
    Functional Controls (Rotates, flips, renames, converts, even toolbar buttons, etc)
    Labels
    "Live" text boxes, combo boxes, etc.
    Image thumbnail
    Image histogram
    Folder contents report
    Etc
Obviously one needs an internal data structure for this, the thumbnail control's metadata. A proper data structure is the hardest part. (I can help with the data structure design, it's my profession.)
But...
If the thumb is implemented internally in this "modular" way, then the user (this means the developer himself, too!!!) could select which panels to display, their attributes, what controls to populate them with, and where to put everything, then save it as a layout (that is: instance of the data structure)!
Given a reasonable "initial" default layout, most users would not make the effort to customize much.
However...
Consider that as the developer, Pierre, you yourself could use the modularity to define the thumbnail interface as you see fit. The development effort becomes simply one of editing the metadata associated with the thumbnail control. You could change any aspect of the thumb (panels, controls, etc) without programming! Instead you would add records to tables in the thumbnail data structure, and the thumbnail "object" would know how to render them.
I know this works because it is how I do it.
Not only that, but this approach is very good for cross platform development because it isolates the implementation of the instance of the thumbnail from the general model of the thumbnail object.
So, with all respect, I again encourage you to step back from the details and try to embrace an even bigger picture for the thumbnail objects than you may have now... and indeed for every aspect of XnView.
Fortunately for everyone: I'm on holiday (again) for a week or so... my dear wife has arranged something else to pull me away from the computer. So no more posts from me for a while! 8)
John
JohnFredC wrote:Fortunately for everyone: I'm on holiday (again) for a week or so... my dear wife has arranged something else to pull me away from the computer. So no more posts from me for a while! 8)
Good news :D :wink:
@JohnFredC: Congratulations, grandfather! ;-)
@thibaud: Thank you very much for providing those excellents drafts which give discussions a good base! :-)
oops66
Post by oops66 »
->JohnFredC: Have a nice holiday !
->thibaud:I agree
One important thing for me (about the most important features) is also to :
1) have the ability to change the font style (type, size,color, ...) into the browser mode.
2) And of course the .ini file as option, for advanced customization (and also for easy user settings backup) .
3) Have the fit to window hotkey "/" available and others zoom functions available into all modes (Browser, View, Full screen), (+ - * are already implemented), what is the difference between hotkey: real size "ctrl+/" and the "*"?
4) Is it possible to have the tabs : Folders, Favorites, categories horizontally at the top left like before, same thing for tabs :Preview, Properties, Histogram, Exif, IPTC, XMP, ... Because this is Consuming less space.
5) Have into the tool bar the Lossless transformations icon available, for rotate ... like the win version.
6) Have available all meta data functions, clear EXIF, IPTC,..., the tool search into EXIF, IPTC, ...
7)Use ((...)) to hide a empty field, to implement as before the {File Index} field
http://newsgroup.xnview.com/viewtopic.p ... light=hide
This is not yet into the MP alfa005 version.
