** English - English (=Master)
Translation of On-Screen texts of XnView MP and XnConvert
Re: ** English - English (=Master)
In a post for the German translation, Herb made two suggestions. (Thank you, Herb!) Both suggestions affect all languages, therefore I repost herb's suggestions here:
Face tag: Warning message
Currently, when writing a face tage, a warning message appears saying that face tags exist which are overwritten. This message should only be displayed if there are really face tages in the image, already. See my post in topic Face tag plugin : Warning message
EXIF tags: "Original"
"Original" >
"Orientation"
    <message>
        <location filename="InfoPropertiesView.cpp" line="135"/>
        <source>Origin</source>
        <translation>Original</translation>
    </message>
herb
Post by herb »
Hello Pierre, hello Helmut,
Please read also: viewtopic.php?f=82&t=43349&p=177615#p177615
Best regards
herb
Moderator & Librarian
helmut wrote: Sun May 08, 2022 11:31 pmEXIF tags: "Original"
"Original" >
"Orientation"
    <message>
    </message>
Judging from Pierre's comment, this has nothing to do with EXIF but with how the image data is stored in the file: “Origin” as in coordinate system (German: “Ursprung”).
https://docs.microsoft.com/en-us/windows/win32/directshow/top-down-vs--bottom-up-dibs wrote:If you are new to graphics programming, you might expect that a bitmap would be arranged in memory so that the top row of the image appeared at the start of the buffer, followed by the next row, and so forth. However, this is not necessarily the case. In Windows, device-independent bitmaps (DIBs) can be placed in memory in two different orientations, bottom-up and top-down.
May I summarize: English text "Origin" is correct and must not be changed. But German translation "Original" is wrong and is supposed to be changed to "Ursprung".
(Please holler if my summary is wrong.)
helmut wrote: Thu May 12, 2022 2:52 amMay I summarize: English text "Origin" is correct and must not be changed. But German translation "Original" is wrong and is supposed to be changed to "Ursprung".
Yes. At least, that's my interpretation of Pierre's comment.
XnView MP 1.3.0 (not released, yet):
___
An error occurs durng saving file! -->
An error occurred during saving!
An error occurs during rename! -->
An error occured during renaming!
Do you would like to export filenames too? -->
Would you like to export filenames, too?
Be careful, changing 'base path' can disconnect files already stored in database, you need this only if you intend to share same folder between computers. Do you want still to change 'base path'? -->
Be careful, changing base path can disconnect files already stored in database. Please change base path only if you want to share same folder between several computers. Do you still want to change the base path?
helmut wrote: Tue Sep 06, 2022 9:29 pm XnView MP 1.3.0 (not release, yet):
Already released :)
I'll changed that
xnview wrote: Wed Sep 07, 2022 7:15 am
helmut wrote: Tue Sep 06, 2022 9:29 pm XnView MP 1.3.0 (not released, yet):
Already released :)
O.k., I didn't know. Rethoric question: How can a new XnView version have an up-to-date and complete translation if translation is done afterwards?
xnview wrote: Wed Sep 07, 2022 7:15 am I'll changed that
Good, thank you.
XnView MP 1.3.0:
Big thumbnails -->
Large thumbnails
XnView MP 1.4.0:
Screenshot: Panel 'Output'
Open in editor
Save to folder
Open in draw module
Open in View mode
Open in Draw mode
Save to folder
AspectPad
Mode -->
Orientation or Layout
Google Map... -->
Google Maps...
Open Street... -->
Open Street Map (OSM)...
rotbus19
Post by rotbus19 »
  • Show files in subfolder > Show files in subfolders
  • Auto image size > Auto zoom
  • Real Size > I don't know! But this label has been confusing people since at least 2008!! The forum is filled with discussions about it. There must be something better to convey it's a calculation of screen and image DPI?
  • Rating and colour label > Rating and color label .... 'color' is used everywhere else?
  • Logarithmic lut > Logarithmic LUT
  • Conbright / Gammasat > confusing made up words!! Is this needed when 'Enhance colors' can do the same and more?
  • Rotate - for Browser it's 'Rotate counter clockwise', for Viewer it's '90` left'. Change both to 'Rotate left' and 'Rotate right'?
