XnView Shell Extension (Support & Development)
Tronje Bäßler
1.93.3 - SE Installation still fails while register DLL/OCX
Post by Tronje Bäßler »
since a couple of versions (I think 1.92.1) any kind of installation (update or clean reinstall) fails while registering XnViewShellExt.dll with exit-code 0x5.
I also tried the stand alone setup and zip-version 2.20 of the shell extension - the same error occurred with error-code 0x8007007e.
My OS is WinXP Pro SP2 english with german MUI-pack.
I hope someone can help me.
Best regards
Tronje Bäßler
Peter2
Post by Peter2 »
Hello
there are many postings regarding the question "Install XnView to USB-stick". What is about XnView-Shellextenison? Is it possible in the same way?
Peter
Re: 1.93.3 - SE Installation still fails while register DLL/
Post by Guest »
Tronje Bäßler wrote:Hello,
Best regards
Tronje Bäßler
Hi man, i have this problem too, My OS is WinXP Pro SP2 in spanish,
any idea??
P.S: Good Program 8)
Peter2
Post by Peter2 »
The current version 2.30 has an old readme.txt (Dec. 2007) and some german strings are missing in the german language file.
Peter
Peter2 wrote:... some german strings are missing in the german language file.
Bummer! I'll check and see...
joby_toss
Post by joby_toss »
Thank you very much !
This shell extension just made my day !
Peter2
Printing with Shell Extension
Post by Peter2 »
Some months ago I made in the thread
http://newsgroup.xnview.com/viewtopic.php?t=13433&
a suggestion:
The software "Shell Picture" (http://baxbex.de/shellpicture.html - no freeware!) is very similar to "Shell Extension", but has interesting print functions.
Maybe you can add print functions too?
Are there some plans to add this feature?
Peter
Hacker
Post by Hacker »
Hello Pierre,
Could you please add an option to resize to relative sizes in %, like 50%(x50%), etc.?
TIA
Roman
Hacker wrote:Hello Pierre,
Ok, i'll add it
Hacker
Post by Hacker »
Ok, i'll add it
Works fine, thank you! :)
Roman
Post by Guest »
Funny thing happened to me today:
I set the ShellExt to open a submenu, and now I can't get it back to the way it was. When I select "Options" from the submenu, I get a screen with information on the file, but not the option screen for the ShellExt I used to get from the "Options" in the main Context Menu.
Any way to fix that other than uninstall and reinstall the whole thing?
Misiaque
Resize improvement
Post by Misiaque »
XnView Shell Extension is a real time saver. However, one thing in it could be improved in my opinion. When resizing a batch of images to, let's say, size of 1280x1024 pixels, portrait images will get a height of 1280 pixels.
I think most of the time it would be more convenient if resizing to 1280x1024 meant that no image will be taller than 1024 and wider than 1280 pixels. So the resized images would always fit into 1280x1024 screen.
Of course there could be a switch between current and propose behaviour in options. I think that would satisfy all users.
Thanks in advance if you consider the proposition :)
Irving
Post by Irving »
I have 2.4.0
It absolutely needs to save the original date and time! :o
Irving wrote:I have 2.4.0
When you use 'convert to'?
