hi
how can i install xnview on ubuntu.
i have download and unpackt.
but ther is no how-to-install-file
Moderators: XnTriq, xnview
Ok, I right-clicked, changed the permission, then, what? Typing sudo ./install did not work. What am I missing?Olive wrote:Right click the file then "properties", "permission" tab, then tick "allow executing file as program".
I believe you'd be better off with the Windows version on Wine though.
I'm running Ubuntu 8.04. Wine is broken in my 8.04 (and for other users, I hear).
Caruso
>carusoswi
You may be able to run old version without installing it. Try ignoring the "install" file and find & run "xnview" from a normal user directory with file manager (I'm using "xfe" when trying this- it has better unarchiving functions than some others).
Aside: About 50% of Windows users download installers. For Linux, a "deb" package is expected .
XnView is running fine under Wine. However if one installs either XnView-x86-unknown-linux2.x-static-fc4.tgz or from XnView-static-fc4.i386.rpm) you only get a dialogcarusoswi wrote:Ok, I right-clicked, changed the permission, then, what? Typing sudo ./install did not work. What am I missing?Olive wrote:Right click the file then "properties", "permission" tab, then tick "allow executing file as program".
Caruso
(XnView v.17) with 3 entries; File Option Info, where the Wine-install gives you a full
XnView-dialog. Anyway, the wine-install runs fine.
WINE = "Wine Is Not an Emulator"
This is not always a good idea !Darkn00b wrote:....
Plus, I refuse to use wine...
Myth 1: "Wine is slow because it is an emulator"
*... As Wine's name says: "Wine Is Not an Emulator": ...
* ...a well written Windows application can beat a badly written Unix application at any time. The efficiency of the algorithms used by the application will have a greater impact on its performance than Wine...
Myth 2:"Wine is bad for Linux"...
Myth n: .....
see here:
http://www.winehq.org/site/myths
XnViewMP Linux X64 - Debian - X64
Download file of this link: http://download.xnview.com/XnView-x86-u ... ic-fc4.tgz
