Join Image Automatic sizing
Moderators: XnTriq, xnview
nyanprime
Postby nyanprime » Sat Apr 29, 2017 8:59 am
I really like the Join Image feature, but I have a few suggestions after using it for a while:
- It would be really nice if you could make it automatically set the strip size according to the input images. For example, if I am making a vertical strip, it could automatically choose width based on the input image with the lowest width. Right now, I have to go through all the images I am joining and see which one is the narrowest and then manually input its width.
- I am only joining images from the same folder, and I would like the new, joined image in the same folder as well. However, when I save the strip, it brings up the save dialog to the previously used folder. So whenever I am joining images in a new folder I have to copy the file path from the browser and paste it into the save dialog in the joined image strip which is a bit tedious. Maybe add an option to set the default save folder of a joined image strip to to the same folder as the input images? (At least if they all originate from the same folder)
Thank you
m.Th.
Re: Join Image Automatic sizing
Postby m.Th. » Mon May 01, 2017 7:27 am
The most natural way is to automatically choose on the widest width, in the way in which it is working now. - just IMHO of course. :)
OTOH, it would be definitely a nice thing to have a button/checkbox/option to select "lowest width/height" (text to change upon discussion). When pressed/checked it will behave in the way in which you described.
The simplest way to implement this is to add a "Save As..." button right in the Join dialog which would take the path of the 1st file as the base path for the Save As dialog which will be opened. I think that it would be ok for you.
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.86 64bit & XnView 2.00 x64 on Win7 x64 -
nyanprime
Postby nyanprime » Mon May 01, 2017 8:25 am
But if you chose a strip width based on the widest image, you'd have to upscale the smaller images.
m.Th.
Postby m.Th. » Mon May 01, 2017 8:32 am
Nope. The engine keeps the smallest image at its size - just adds the background color around. The "Alignment" drop-down controls how the smaller image(s) will be placed.
m. Th.
nyanprime
Postby nyanprime » Mon May 01, 2017 8:42 am
Okok. I realise I should have prefaced the first post by saying that I generally don't want the background color fill :P
Return to “MP - Suggestions”
Who is online
Users browsing this forum: No registered users and 3 guests
